It is currently Sat Sep 13, 2025 11:11 am
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 76 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: My challenge build
PostPosted: Sat Feb 18, 2012 4:48 pm
First name: Phillip
Last Name: Patton
City: Yoder
Zip/Postal Code: 46798
I've started working on the tailpiece again. My old 4" angle grinder broke, so I had to get a new one.
First the wheel is shaped so that it will make a round groove, then grooves are cut on both sides of the billet, offset from one side to the other.
Before grinding:
After:
To be continued...
Regards,
Phillip Patton
http://www.pattonblades.com
The bitterness of poor quality lingers long after the sweetness of low price has faded.
https://hoosierbladesmith.wordpress.com
PostPosted: Sun Feb 19, 2012 4:47 pm
First name: Phillip
Last Name: Patton
City: Yoder
Well, the binding is all glued on now. I'm not real happy with the fit of the top bindings though. Before I do another archtop, I need to build a binding router jig thing...
I painted the channels with shellac first:
The bindings. They came out of the bender a little lumpy in some spots, so I had to touch them up on the iron:
I also worked on the fingerboard a little. I tapered it and added side position markers:
I'll finish forging the tailpiece tomorrow, and will probably be able to string it up, "in the white", shortly thereafter.
Regards,
Phillip Patton
PostPosted: Sun Feb 26, 2012 9:28 am
First name: Phillip
Last Name: Patton
City: Yoder
I actually haven't done anything on this project since last weekend, but here's some more pics from then.
The binding scraped on the top and back. Have to do the sides yet:
The inserts, inserted:
The neck joint flossed:
The wedge glued to the neck:
The fingerboard radiused:
Regards,
Phillip Patton
PostPosted: Sun Feb 26, 2012 9:32 am
First name: Phillip
Last Name: Patton
City: Yoder
The tailpiece. Sorry, I missed some intermediate steps. Basically, I drilled the holes, then used a torch to soften the area I wanted it to bend, and bent it. I think I may be scrapping this one because it's not wide enough. We'll see.
I used a small cut off wheel in my Foredom and needle files to make the string slots.
Regards,
Phillip Patton
PostPosted: Sun Feb 26, 2012 9:43 am
First name: Big
Last Name: Jim
I really like this build Phillip . love the wood combo and the steel work . I really look forward to seeing the finished product and hearing her played . great work [:Y:]
PostPosted: Sun Apr 08, 2012 6:06 pm
Last Name: Kincheloe
So how's this baby coming along? Waiting for finish to cure, or do you still have it strung up in the white? And what are your thoughts on eastern red cedar as a top wood? There's a guy over on delcamp asking about it, says there's a guy somewhere in Missouri with a bunch and could cut guitar tops if there's interest.
Excellent work, by the way. I think this is my favorite build in the challenge so far. Love the color scheme, shape, F holes, everything. I've been wanting to try an arched top with flat back like that, and wondered why nobody ever did it. Arched back makes sense for soundpost instruments, but flat seems like it would work better for guitar style instruments... plus it saves a bunch of wood and painful hardwood carving. Carving the top is fun though :)
Definite points for forging your own steel tailpiece [:Y:] Looks great. Not a fan of the hex bolt though. Stick a wood pin in that thing!
Can't wait to hear sound clips.
PostPosted: Sun Apr 08, 2012 7:35 pm
State: Tennessee
Really cool build. Nice job carving the plates.
I replaced some plastic handles on some chisels with curly maple and used copper pipe for ferrels, your hand made ones look really nice.
I've been into forged knives for a long time, I have a couple of Jerry Fisk knives, should have three one got stolen.
PostPosted: Sun May 13, 2012 10:25 am
First name: Phillip
Last Name: Patton
City: Yoder
It's coming along pretty well. I hadn't really done anything on it for a couple months, then realized the deadline is quickly approaching, and I'd better get moving. duh So, a few weeks ago I shaped the neck, and this week finished sanding and started spraying.
I did have it strung up in the white, and it sounded pretty good. I think the eastern red cedar is fine as a top wood, but you won't see it used much, since it's so hard to find pieces big enough without knots.
Don't worry, I'll be making an osage endpin. :)
Sorry to hear about your Fisk getting stolen. What models do you have?
Ok, here's the first round of the semi-final pics:
The neck before shaping:
I use a belt grinder called the KMG (knife makers grinder) from Beaumont Metal Works. A wonderful tool. I'd be lost without it.
Here it's set up with the small wheel attachment:
After shaping the way I want, I use a different attachment, with a slack 240 grit belt to remove the 40 grit scratches:
All smoothed out:
I'm finishing this neck with Tru-oil. Here it is with one coat on:
Regards,
Phillip Patton
PostPosted: Sun May 13, 2012 10:31 am
First name: Phillip
Last Name: Patton
City: Yoder
I decided I didn't like the color of the top, so I'm painting it gray:
Just kidding! I'm actually using the paint to help me find any imperfections on the top:
I'm not pore filling this instrument. I'm doing a quick and dirty finish. First, a couple coats of shellac, then sand it smooth:
Regards,
Phillip Patton
PostPosted: Sun May 13, 2012 10:35 am
First name: Phillip
Last Name: Patton
City: Yoder
Then lacquer. I'm using Watco brushing lacquer, because I have it, and want to use it up. Since I'm not pore filling, it would be pointless to sand this all the way up through the grits and buff, so I'm just going to spray a dozen coats, level, then spray one more very thin coat.
At this point, I need to let the lacquer harden a couple days before I level it. This brushing lacquer takes awhile to harden...
Regards,
Phillip Patton
PostPosted: Sun May 13, 2012 11:26 am
First name: Phillip
Last Name: Patton
City: Yoder
Now, the tailpiece.
I heat treated it because hardened and tempered damascus gives much better contrast than soft (annealed).
Before etching:
After etching:
After buffing:
I repeated the etching/buff process a couple more times, etched it one last time, and left it in the neutralizing bath for several weeks. Then I lightly sanded it with very fine paper to bring a shine to the bright layers, while leaving the others dark. Then I sprayed several coats of lacquer to keep prevent rust. As soon as I find the tailpiece, I'll take some pics of it...
Regards,
Phillip Patton
PostPosted: Sun May 13, 2012 12:18 pm
First name: Phillip
Last Name: Patton
City: Yoder
I found the tailpiece. Miracles do happen.
Regards,
Phillip Patton
PostPosted: Sun May 13, 2012 1:34 pm
State: Tennessee
That damascus tailpiece is cheating........ thats awesome. Would you be interested in doing a couple of mandolin tailpieces?
PostPosted: Mon May 14, 2012 9:20 am
First name: Patrick
Last Name: Hanna
State: Missouri
It's a very cool little instrument, Phillip. I've enjoyed following along with it. I like your choices throughout. At first, I didn't think I'd like the bindings, but they work very well. I'm especially impressed with the way you brought out the pattern in the damascus steel. That's beautiful.
Patrick
PostPosted: Sun May 20, 2012 6:46 pm
First name: Andrew
City: Ottawa
State: ON
That tailpiece is awesome. So after you cut grooves into it, did you just hammer it flat, or was there more to the process?
PostPosted: Wed May 23, 2012 11:30 am
First name: Phillip
Last Name: Patton
City: Yoder
Hmm, maybe. The design needs some tweaking first.
Yes, after grinding the grooves were cut, then I hammered it flat, then forged it down to the final as-forged thickness, then ground it down to about 1/16" thick.
Ok, here are the final in-progress pics:
Making the tail pin:
Next post, finished pics.
Regards,
Phillip Patton
PostPosted: Wed May 23, 2012 11:33 am
First name: Phillip
Last Name: Patton
City: Yoder
Assembly was just a matter of bolting everything together. And adjusting the bridge height. I'm not sure I'll leave the bridge the way it is. I might "skeletonize" it like a violin bridge.
Regards,
Phillip Patton
PostPosted: Wed May 23, 2012 11:35 am
First name: Phillip
Last Name: Patton
City: Yoder
More pics:
Now I just have to find someone who can play something I can record and post...
Regards,
Phillip Patton
PostPosted: Tue May 29, 2012 11:07 pm
First name: Phillip
Last Name: Patton
City: Yoder
I just recorded my demo video:
http://www.youtube.com/watch?v=9AwZVjgl ... e=youtu.be
Regards,
Phillip Patton
 Post subject: My challenge build
PostPosted: Wed May 30, 2012 12:10 am
First name: Tony
Last Name: C
City: Brooklyn
Outstanding!! Sounds great and you get bonus points for making the Damascus tail piece!!
http://www.CostaGuitars.com
PMoMC
PostPosted: Wed May 30, 2012 4:07 am
First name: Trevor
Last Name: Gore
City: Sydney
Nice, Phillip. Scarborough Fair rules!
http://www.goreguitars.com.au
PostPosted: Wed May 30, 2012 8:55 am
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Nice!!!!!
duh [clap] [clap] [clap]
PostPosted: Wed May 30, 2012 9:19 am
First name: George
City: Seattle
That's awesome, Phillip! And cool documentation of your process as well.
George :-)
PostPosted: Wed May 30, 2012 2:13 pm
First name: Andrew
City: Ottawa
State: ON
I love the sound. It's sort of like a mando but smoother.
PostPosted: Thu May 31, 2012 8:49 pm
Last Name: Shanklin
City: Windsor
State: ON
Great work, and documentation, Phillip.
